伺服驱动器如何避免干扰
512 0
<p>1:加装电源滤波器,</p><p>2:一点接地原则<span style="color: rgb(51, 51, 51); font-family: Arial, sans-serif; font-size: 14px; text-align: justify; background-color: rgb(255, 255, 255);">将电源滤波器的地、驱动器PE(地)(伺服驱动器与机箱底板绝缘)、控制脉冲PULSE-和方向脉冲DIR-短接后的引出线、电机接地线、驱动器与电机之间电缆防护套、驱动器屏蔽线均接到机箱壁上的接地柱上.</span></p><p><span style="color: rgb(51, 51, 51); font-family: Arial, sans-serif; font-size: 14px; text-align: justify; background-color: rgb(255, 255, 255);">3:<span style="color: rgb(51, 51, 51); font-weight: bold; background-image: url(&quot;https://t8.baidu.com/it/u=1501552470,2690656309&amp;fm=167&amp;app=3000&amp;f=PNG&amp;fmt=auto&amp;q=100&amp;size=f624_21&quot;); background-repeat: repeat-x; background-position-y: 100%; background-size: 100% 8px; font-family: Arial, sans-serif; font-size: 14px; text-align: justify; background-color: rgb(255, 255, 255);">尽量加大控制线与电源线、电机驱动线之间的距离。</span></span></p><p><span style="color: rgb(51, 51, 51); font-family: Arial, sans-serif; font-size: 14px; text-align: justify; background-color: rgb(255, 255, 255);"><span style="color: rgb(51, 51, 51); font-weight: bold; background-image: url(&quot;https://t8.baidu.com/it/u=1501552470,2690656309&amp;fm=167&amp;app=3000&amp;f=PNG&amp;fmt=auto&amp;q=100&amp;size=f624_21&quot;); background-repeat: repeat-x; background-position-y: 100%; background-size: 100% 8px; font-family: Arial, sans-serif; font-size: 14px; text-align: justify; background-color: rgb(255, 255, 255);">4:使用屏蔽线减轻对外界对自己的干扰,或自己(电源线)对外界的干扰。</span></span></p>
