风机变频器无法启动是什么原因?
967 0
<p>1、电源电压不稳定:检查电源电压是否正常,如电压过低或过高,应及时调整电源电压;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;</p><p>2、电机绕组短路:检查电机绕组是否短路,如发现短路现象,应及时更换电机绕组;&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;</p><p>3、电机轴承过紧:检查电机轴承是否过紧,如发现过紧现象,应及时调整电机轴承;</p>
